my 1950 Schwinn Traveler (?) project
49autocycledeluxe
it had two Schwinn tires, could be original. front had a few patches on the tube. haven't taken the rear tire off to see what is inside the rear. you can patch a tube with the wheel on the bike. I would bet there had never been a wrench on the handlebars or stem.
SirMike1983
The clamping of the pulley is less important than that the wheel turns to accommodate movement of the shifter cable as you shift. I suppose you want to remove the pulley to check for rust on the frame underneath, but as long as the wheel turns, that will function. If the wheel is frozen, you will have to work at it to get that small axle screw loose and free the wheel. They don't shift well with a frozen wheel and it accelerates wear on the cable.
49autocycledeluxe
the wheels spins, hopefully the screw comes out so I can remove the pulley and clean it up real good with a Dremel or something. I have been putting PB Blaster on it. maybe it will come loose if I give it another try.
took some items from the "bath" this morning before work. that is amazing stuff. the headset and the brakes came out very nice, except where the chrome had flaked on some of the brake parts. crank and kickstand cleaned up way better than expected. pics later.
1motime
Piece by piece. Then they can go back together. Sounds like is going OK! Even if everything is not perfect it should be a great riding bike. If it shifts OK you have a good one
49autocycledeluxe
"then they go back together" .... I think if I had it to do over again I would put like one complete disassembled brake in a jar with its own evaporust. then I would not have to sort through all this little hardware to figure what's what. a little jar for each sub assembly. I'm sure I'll figure it out, but it would have been simpler if they were separated beforehand
1motime
No instructions included. The learning curve can be enjoyable also!
49autocycledeluxe
clean parts.
I got the bell to ding. I may have to do surgery to make it ring.
1404771
49autocycledeluxe
I think before I go any further I will reassemble the brakes. too many tiny washers and such! fenders and wheels next. I have the tip of the front fender in my little tub right now, we'll see how it goes after work. need a bigger tub.
