TheCABE is an affiliate of the eBay Partner Network. When you click on eBay links and make a purchase, this can result in the site earning a commission.
My Simplex Servicycle build.
mikecuda
I am installing a Worksman drum brake wheel on my Simplex. I was thinking about using a 420 chain. What sprocket and size do U recommend??? The wheel may be a front Worksman wheel, therefore it won't have a threadedf hub to screw on a sprocket. I have to check it once I go to the location where it's at.
Honda GC190 4 stroke going on it. Not sure if I'm going with drive belt or chain. Aweful tight in the engine bay area to use the Simplex pulley system. Maybe direct drive chain and sprocket off the centrifugal clutch.
