If you can find aluminum blocks like in pic. You could lay stem across with high spot of bend at Top dead center. With another block then using a press it will move it. These pieces were similar to blocks I used to straighten AS button bars. After watching brother straighten HD crash bars I used rubber shims in larger blocks to reduce dia.+ save chrome on old crossbars.
Thanks guys, so I went with my instincts; found a piece of round stock, inserted it to near the bend area, and then applied heat from propane torch. Gentle persuasion did the trick!
