rennfaron
I would test out that magic eraser trick first on a small area. What might look like dirt embedded under the surface but may be dirt embedded on the surface and into the decal. Those magic erasers are like a very fine pumice stone and slowly strip away layers. You may get some of that embedded dirt off with the erasers and then follow up with the Micro sol / set to improve the look of the decal. And there is no equivalent for the magic eraser, like oh I will just use this instead. I tried a bunch of different things in lieu of the erasers, to not spend the money, and it's gotta be the magic eraser... As you know it is all about the right tools and right sequence of processes to get the best results. Sometimes I hate all the crap I have to do to get each part to look good because each part / material requires something different.Very interesting! I actually have some of this stuff. I used it back in my model building days 25+ years ago. I hadn't thought about using it to repair bubbled bike decals, but seems like aught to work just like you suggest. I think in the case of my bike though, with what appears to be dirt under the clear part, it wouldn't help... but it may be worth trying anyhow.
