Need Dimension from Postwar Monark Springer ~ Leading Fork Spring Tower Height?
Krakatoa
Help!!
Hoping someone here has a postwar Monark Men's Springer apart and can give me the pictured dimension.
I need to shorten and re thread the spring towers on this ladies leading fork, the steering tube has already been done.
Thanks!
Nate
@TheFizzer
piercer_99
ricobike
I just checked on another one I have, a 52 and it was 5 1/4 inch. The other one was a 49.
Edit: Just checked another one, another 52, also 5 1/4 inch.
I'm measuring from where the spring sits at the bottom to the top of the threaded part.
the tinker
Which yoke is on your springer? Super Deluxe
1227415
or the older style?
1227416
5 1/4 super. . . 4 3/4 on the older one. Measure your springs. If your using re-pop springs they may be a little different. The girl's springers had the spacers for the longer head tube. The pre war yoke was used well into the fifties on standard girl's bikes with spacers.
1227506
The tall one on the right being the standard spacer used, but the shorter one was also used. Assemble your springer before you cut it, and see how the springs fit. Those threaded rods are easy to replace, as they sometimes become loose and come out. New ones are simple to make and can be securely set in place with J.B. Weld.
jlively970
Fork dimensions!! Love it, wish we had catalogs of microfiche blow ups and dimensions! Awesome Cabers have all the answers!
