Need help identifying 1952 schwinn model?
Kevin Mac
Hello,
I recently picked this bike up off Facebook. The guy said it was a 1954 B6, upon closer inspection the serial D31637 reveals it is a 1952, but doesn’t say which model. Is this a B6/autocycle or phantom? Because it seems to have similar paint designs and the same springer fork. I know the frame, fork and supposedly the bars are original. Not sure what else. My intentions are to get some S2 wheels which would be correct for this bike? And a original tank in crusty condition to match its looks if I can find one. Correct pedals would be nice too. Also want to remove the headlight and rear fender because not original?
Bike does ride nice though.
Thanks, Kev
1947-48 and could have been a B5 or B6. Tell tail signs of having a tank so most likely a B6. Could have been equipped with the brand new S-2's depending on the actual build time but I would guess it came with drop centers.
Thanks for the information. Did the tanks stay the same through the years of the B6? Is it hard to find drop centers?
Post war tanks the same except Phantom were chrome. You would want a plain steel tank. Drop centers are easy--and cheaper than S2s most of the time. If you wanted to make it right you would also need a seat, fenders with fenderlight, pedals, rack, guard, and grips. By the time you did all this you could probably buy a decent B6. I'd just make this a cool rider. V/r Shawn
What he said.
If you look at catalogs for those years, you'll also notice that the chain ring is from a later bike. My 52 has a skip tooth chain and the Phantom style chain ring. PO could have swapped chain rings to use a single pitch chain with those fancy rims.
Ok so if I wanted to change to the original wheels I would have to change that?
