Junkhunter
Hi guys. i need help with figuring spoke lengths. I tried to use a couple of the online spoke calculators but didn't really get anywhere. I'm trying to build 2 sets of wheels using the Stutzman wood rims with the aluminum insert. 1st set I want to use a Bendix 2 speed kickback hub. I got a hub that has a skip tooth cog on it. Someone made it custom. I want to lace it into a wood rim. The 2nd set I want to use a New Departure Model D. Reasoning behind that is I have available to me one of those 2 speed set ups. The model D is such a good hub anyways it seems to be a no brainer. I can give some specific measurements. The hub flange width is 2.25". The measurement across is 3" hole to hole.(looking at it from the axel end) The measurement across the rim is about 24 1/16". (Where the spoke end would be) I've carefully taken a few metal clad rims apart over the years and I have a lot of those spokes and nipples left. i thought it would be really cool if I could reuse those spokes (cut about 1/2" off I think and rethread I think) to build the set I'm using a Model D on. Then get some copper wire and tie them. i spoke to a guy that has a spoke cutter and he thinks he can reroll the threads back on. All of those old long nipples could be used too I hope. If I can find someone to help I can get front hub dimensions too. i am using ones I've saved from old wood wheels.
