Need some help on this one guys
bentwoody66
2,768
54
Middletown Ohio
What brand is that front tire???
Sent from my SM-G950U using Tapatalk
Jesse McCauley
McCauley Cycle Works
Mar 5, 2013
2,353
Richmond, Virginia
I have a Snell Special featuring a larger version of the same chainring and the same seat stay wrap around lug.
Uncommon bike from a very reputable company.
Darj
On Training Wheels
Apr 4, 2020
7
43
Canada
What is the age of my bicycle?
Archie Sturmer
1,542
Los Angeles, CA, USA
William H. Fauber of Chicago star chain ring sprocket.
Handle bars look upside down.
Reactions: Darj
Waffenrad
52
I think you all have identified my own favorite bicycle. I bought mine as a frame-set fifteen years ago and built it up as a rider for Wheelmen centuries. Mine also has the original Fauber cranks and large chain ring of a different pattern. The frame details and compression fittings at the seat and stem match exactly. It has original blue paint and silver pinstripes, and lots of nickel. I completed it with a New Departure Model A coaster-brake and matching front, continental 28 x 1 3/4 (700C) steel rims, a nickel continental spoon brake, period TOC rat trap pedals, and a Brooks B72 saddle. Like I said it is a rider not an authentic restoration. But it is a light, comfortable, great riding bike. I have ridden it literally thousands of miles now. The one critical missing piece was, as always, the head badge. I don't think mine was 'stolen.' There is a small dent where I think it came off in an accident. Jesse, could you take a closer picture of your head badge? I'd love to see what I'm missing!
Thanks, Paul Rubenson
1229403
Waffenrad
52
Here is another Snell, that is currently for sale. It interests me that the seller says the bike originally had 30" wheels! My frame and forks are relatively tight around my 700x38C tires. Slightly larger 28 x 1 1/2" TOC tires would certainly fit, but I can't see 30". I wonder if these bicycles were possibly offered in both 28" and 30" variants.
I'm interested to know if Darj's Dunlop tires are true Dunlop-type wired-on ("clincher") tires, and not single-tubes. I have a pair of TOC Dunlop-style wood rims, but I can't find any current size tire that fits them. Is there a size marked on your tires???
A last question for Darj is if your stem bolt holds your stem to the fork, or just the handlebars in the stem. My bike has a compression fitting at the stem similar to the seat post. Your headset parts look the same, but my stem doesn't have a center bolt.
Reactions: Darj
Darj
On Training Wheels
Apr 4, 2020
7
43
Canada
I believe my tires to be clinchers..marked 28 by 1 1/2.not sure if the stem holds the fork or not..is the bicycle pictured yours or is that the one that is for sale?cheers
Waffenrad
52
My bike is the blue one pictured higher up. The dark one immediately above with dropped bars is for sale by Caber Carlitos60. Assuming your rims are original, then some day I would like to restore my Snell similarly with wood clincher rims. Like I said I do have a pair of wood TOC clincher rims. But so far I haven't found any modern tires that fit them. Modern 28" x 1 1/2" (ISO 635) roadster tires are too large if I remember. But I think ISO 630 and 622 were too small. I wonder if it's possible to research or figure out the ISO of your TOC clinchers.
When I look closer at Carlitos60's bike I can clearly see it originally had bigger wheels than mine. His current tires are 700 x 35 and there is tons of room around them, like three inches. It was clearly a 30" wheel bike as he says, while mine is definitely only a 28". But the head tube appears the same length on all of them.
Thanks!
Paul Rubenson
