I have seen alot of threads and place that show model d manuals calling for automotive grease on the bearings and oil on the steel/brass disks.
My hub im working on is all cleaned and ready to go back together.
Right now im thinking of using phil wood grease on the bearings. Will this suffice?
Also....my hub doesnt have a oiler hole on it which i thought is strange. Do i just soak each disc with a 30w oil and slide them on the shaft and call it done?
Do i need to oil or grease up the splines and teethed parts that fit together containing the spring mechanism? IF so...which? Oil or grease?
Thanks all. Id rather only have to do this once and i want to get it right the first time
