Due to some recent accounts having their passwords hacked, we are requiring that everyone set a new password. On your next login, you'll be given the option to choose a new one. Please follow current password guidelines for secure passwords. Sorry for the trouble!
If someone has already documented this, I apologize. Parts needed: clutch, 1 inch grade 2 nut and one 2 3/4 inch long grade 8 bolt with nut and washer. Procedure: Weld clutch to 1 inch nut. Thread driver into clutch and fasten with the 3/8 bolt. Hand tighten. Put the assembly in a vice and apply...
Wanted to swap out the 9t rear cog on my girl's '40 Twinflex to a 10t for easier riding on this portly broad. I took @rustjunkie's advice and it worked like a charm. Thanks bud! If wheel/hub is out of frame: Loosen lock ring (it has a reverse thread) just a bit. Put hub or wheel into frame or...
