37fleetwood
Riding a '37 Fleetwood
my main worry was finding a Sturmey with a coaster brake since I didn't want to have to run brake cables and levers and mount the brakes themselves. I don't know if it is clear that I intend to run modern chain. I am not going to use skip tooth chain. I thought about going the route you mention but it is so much cheaper to simply go to regular modern chain and I don't think I could find a hub with both, a screw mount sprocket, and coaster brake. I have a 36 spoke Sturmey coaster brake hub that I have had laced into a 26" drop center rim. it will look the same basically except the shifter cable. 2 and 3 speeds were available just not this type. from 1938-1940 Huffman even offered regular 1/2" pitch chain. maybe I should find a 52 tooth Monark sprocket instead since that is the sprocket they seem to have used .
thanx.
Scott
thanx.
Scott
