OLd Chain Questions
hwstem
I have a Columbia tandem from 1897 and want to take the wheels off to get it out of the attic that it ia in the. Stairway has a 90 degree turn and it will not fit with wheels. 50 years ago when it was put up there the attic had a differnt entrance. What I was wondering is is will a modern chain tool work on chainfrom 1897? If not were can I get a chain tool that will work?
ejlwheels
You may not need to remove the chain that way to remove the rear wheel. If the rear wheel dropouts have chain tension adjusters, then loosen those first and you may be able to remove the chain from the sprocket and the remove the wheel. And/or some old chains have a master link, look for that. If if is block chain, most block chain cannot be taken apart with a chain tool as the end of the pins are peened.
Walker
You might get lucky and find a repaired area of the chain, my 1989 Davis had a tiny bolt/nut in place of a pin. Someone must have done a shade tree repair at some point. Good Luck nonetheless!
hwstem
My bike has a screw with a nut on it, on both chains that will not come apart I have tried WD-40, PB Blaster and Liquid Wrench. Would drilling the screw out be a terrible idea?
sam
Try heat---like the flame on a gas stove ---a friend was told to do this to remove nipples from old spokes---worked great for him.
