Bike from the Dead
Hi guys,
So, I’d been doing some research on oxalic acid baths for removing rust and shining up paint on old bikes, and I decided that I wanted to give it a try on some of my bike projects. I think I know what supplies I need, and I think I understand the process, but I’ve found that there’s a bit of conflicting information on how to do an oxalic acid bath.
Here’s what I’ve basically learned so far:
Supplies I’ll want to do an oxalic acid bath:
1. Oxalic acid/wood bleach (I got 2 12oz tubs from Ace Hardware)
2. 1-2 kiddie pools big enough to fit my bike parts in
3. Gloves
4. Simple Green or vinegar to remove any grease and dirt from parts before the bath
5. Tooth brushes to remove yellow film from parts during bath
6. Soap and water to wash off parts after bath (Would Dawn work?)
7. Air compressor for drying
8. Rust inhibitor to spray inside of frame and forks after bath
9. Wax to protect paint/chrome/steel from rusting again (I’ve heard a few folks recommend Johnson’s paste wax, but I don’t know of any stores that carry it. Would automotive wax work?)
10. Scotch Brite no-scratch pads to wipe off parts after bath
11. Micro-fiber cloths for waxing
The process as I understand it:
1. Disassemble bike
2. Clean off any dirt and grease from any parts using either Simple Green or vinegar, depending on whether or not the part is chrome?
3. Once all parts are cleaned, place in kiddie pool full of warm water. I’ll be doing this when the weather is warm and sunny out, so I take it that I’ll just have to let the water warm up on its own.
4. Mix at least a couple tablespoons of oxalic acid into water. It’s okay if the solution is weak, as more OA can be added if needed.
5. According to some, this is when you pull out a 6-pack of beer and start drinking. Given that I don’t drink, I’ll substitute this step with lemonade or something.
6. After a few hours, a yellow film should develop on the submerged parts. Remove yellow film with toothbrush while sitting in the solution.
7. After all rust and yellow film appears to have been removed, gently wash off parts with soap, water and pads. (Seriously though, what kind of soap do I use?)
8. Dry parts with air compressor and a micro-fiber cloth
9. Spray inside of frame and forks with rust inhibitor. Wipe it off if it gets on the outside of the frame and forks. Allow it to dry.
10. Gently wax parts with micro-fiber cloth and reassemble.
11. Take your shiny rust-free bike for a ride!
Okay, now that that’s out of the way, here’s where I get a little lost:
1. So it’s fine for the wheels to be put in the oxalic acid bath whether they’re chrome or painted, but the spokes, spoke nipples, hubs and axles are not okay to place in the bath?
2. Is it okay to dump the used solution into my lawn, or not? Some say it’s fine if I pour some additional water over the spot, others say don’t do it at all but don’t say how to dispose of it, some even just dump it without doing anything else. So, which is it?
3. What kind of soap do I use to wash off the bike parts after I take them out of the bath? I know some stuff doesn’t react well with the oxalic acid, but how do I know which kind of soap to use?
4. Does it matter what kind of wax I use to preserve the finish from rusting further, and how would you apply it? I don’t have a buffing tool, but I have micro-fiber cloths. What sort of wax would you recommend that I could find at Walmart?
I had originally given up on doing an oxalic acid bath on my bikes when I decided that I wouldn’t risk my health or others’ health by getting the few remaining supplies I needed after the coronavirus was officially declared a pandemic in the U.S. However, since my parents still plan on going to Walmart and a few other places at this time, and had offered to get the last few supplies I need to finish some of my bikes, I’m going to go ahead and move forward with this. I’m still worried about getting sick, so I’m staying home regardless, but just because I’m staying home doesn’t mean I can’t go do some work on my bikes out in the yard.
So, what do you guys think? Do I pretty much have the whole list of supplies and steps down right, or is there something I missed? Any help or advice is greatly appreciated.
Also, here are my sources for my earlier research, in case you’re interested:
https://vintageamericanbicycles.com/index.php/2019/07/25/saving-a-rust-bucket/
https://bmxmuseum.com/forums/viewtopic.php?id=351132
https://thecabe.com/forum/threads/oxalic-acid-on-paint.53809/
https://thecabe.com/forum/threads/oxalic-acid-bath-before-and-afters.64373/
https://thecabe.com/forum/threads/how-to-clean-rust-off-the-bike.14561/
https://thecabe.com/forum/threads/m...cid-to-water-for-a-bicycle-frame-bath.143259/
https://thecabe.com/forum/threads/another-oxalic-acid-bath.120503/
https://thecabe.com/forum/threads/oxalic-acid-bathing.119924/
https://thecabe.com/forum/threads/n...due-from-chrome-after-oxalic-acid-bath.85055/
3. Gloves
1. Disassemble bike
