Starting to unwrap parts. The bike was completely disassembled except for removal of headset pressed-in parts, and hubs. Saves me some work, and saved a lot of cash related to shipping (about $120 from Italy) a complete bike.
Everything was individually wrapped so taking a bit of time, but happy for the diligence used in packing.
Here are the rods and axle releases. I'm not sure if the front and rear QR adjustment nuts are of the same vintage unless those gripping bolts were intended as different styles or the bolts on the front are replacements for lost originals. I would prefer the rear adjustment nut bolt style if anyone has some (functional condition is OK).
I also know there are different rod lengths (Corsa, and [later post '48?] Sport versions), but no reference as to a year, or which size was specific to each model (I assume the Corsa was shorter rods, but just a guess). I don't believe the Campy catalogs make any mention of the two versions.
I have measured both rods, and the axle release rod is approx. 28.4cm from upper bend at handle to the center of the QR rod assy. The shifter rod is approx. 14cm from bend to bend. Now we have some sort of length reference for one of the versions. I ask others to measure their rod lengths and see what sizes are out there, as well as providing the approx. year of the bike it is mounted on (if applicable).
I have not checked the drop-out tooth count yet so I don't know if it is the 17 or 19 tooth style.
All hardware thus far has been in very good condition; no rust except very little on the lower part of the shifter rod, the front QR lever and adjustment nut grip bolts.
