Paint removal to see original paint
Michael Boyd
Hi Guys
I’ve looked and searched here and can not find a thread that simply tells the procedure for removing paint to get to original paint (and not harming the original)
If anyone can point me to a thread or just tell me the process, I’m ready to start on my Shelby WF
THANKS
Mike
The seller had buffed it to show the number , looks like it may be red paint underneath, but again, love to know how to remove the brown paint to get to the red and hopefully bring it back to life.
There's no one size fits all when it comes to removing newer over coat or, as called; house paint. Original paints are, in general harder than over coated house paint jobs yet, some are so hard, for age maybe, it can be really tough to break it down without breaking original paint at the same time. Moreover trial and error starting light and working up the scales unless, ya got a super great load of elbow grease and capable of gently sanding/skinng the house paint off without going too deep.
IDK what you are expecting too B/C it also looks like it got a decent sanding before rattle canned. Regardless, if it is primers on it, Maybe acetone, (nail polish remover) U could also try various thinners especially leaning on Tulane or lighter easier on the paint, paint removers. Goof-off might work on yours B/C it looks like a recent primer sprayed on but ya gotta be careful; to much or too long can begin loosening the original paint.
There is not one perfect solution for every type of "house paint" used - many paints have different formulas just like the many different paint removers - I had great success with the GOOF OFF product on whatever was used as a house paint over this tank - I worked a small spot at a time & a large bath towel that I constantly moved so I always had a clean area on the towel with fresh GOOF OFF on it that as I used the new spot on the towel I would do a quick last wipe over the area just revealed
The GOOF OFF would soften the old house paint - then it would smear it & then the new area on the rag would make it 90% there - Let the product - in this case GOOF OFF - break down the old house paint - RUBBING IT HARDER WILL NOT MAKE THE GOOF OFF WORK ANY BETTER - Gentle motion - well ventilated area - or open area outside & PATIENCE .. this tank took me 5 hours to clean up - but 100% worth the patience - original paint under house paint isn't guaranteed depending on how how much was there and/or condition before it was painted & how the painter prepped the surface to begin with
Too much of any remover may remove it all .. so again work on small areas and with plenty of patience - I have found that white house paint is the most difficult to remove with any type of thinner
I've also used more & less aggressive thinners - from lacquer thinner - to paint thinner - to acetone & more - each house paint has a product that may work against it to reveal original paint which is surprisingly strong depending of brand of bike - Schwinn is really strong paint from the factory - many others not as strong - In the case of your Shelby - paint is on the thin side prewar .. so be careful & best of luck .. keep us posted on progress
Ridden not Hidden - Frank
