Park Tools FT-4 FORK CLAMP AND GAUGE
atilly
Finally the "sticks"or FFG-2 are indicating misalignment on white fork at top of post . It looks minimal + it looks like inner guides are tapered like a valve seat. Maybe outer registers are the flat of tightening nut.. Wouldn't larger washers work as well. Are the sticks secure enough to tweak - fork ends
Yes, I agree, the white forks a the top of the post are slightly off. There is a possibility that the FFG-2 are not centered in the fork tips. There is a difference between the size of a dropout slot and the size of the FFG-2 "axle" which can lead to this.
Yes, the FF-G 2 are secure enough to tweak fork ends, the question for me is "am I strong enough to do it?" This fork is off a modern Chromoly mountain bike and is VERY stiff.
atilly
A good friend agreed (was hoodwinked) to help (do all the work) build a Fork Jig. A walk through the scrap metal racks and a stint at the bandsaw produced some building blocks:
Fasten your seat belts, looks like we are following Alice down the rabbit hole...
atilly
The fastener pattern is repeated for each edge, the box is formed. Again, this is more akin to the Var use of bolts (no welding) and not like the Park tools design (rectangular tube and welding) that @ivrjhnsn is adeptly using. The end result should be the same, the differences fall into the "how much would it cost to manufacture" realm. Aside from the fasteners, the functional design of this knock-off is loosely based on the Park Tool FT-4 and not the Var 478.
berniebike
Well golly. I only seldom need to check and straighten forks, but when I do th FT-4 is the right tool for the job. Dissapointing to read they are no longer being manufactured, althouigh I guess most modern forks are not serviceable iwith the FT-4 as they are Aluminum, Carbon, or suspension. I wonder if there are liability concerns selling a product that encourages someone to bend on a critical bicycle element like a fork...
I wonder how hard it would be to make one; a fork jig that is solid and (almost) as good as the Park Tools FT-4
i have one of these and have performed miracles with it.might actually be putting it up for sale soon.i,m going on 66 years old here and havent touched it in years..most shops stay away from frame and fork straightening for liability issues.i have done plenty of frame and fork straightening.and i do know my limitations.i would not send someone out on an unsafe ride.
buickmike
What if you could drill a hole in main structure to allow the upper legs of Schwinn springer to be locked together. Could we then check straightness of legs from the middle down. ?
