Freqman1
Since at least a few of us are interested in these I think we should have our own thread devoted to these shifting systems. The short story is these were developed before the war by Campagnolo although I question whether, other than a few prototypes, these actually went into production until after the war and more specifically about 1947. Cambio Corsa loosely translates to race gears and was also called the due leva (two lever) shifter. The Cambio Corsa drivetrain consisted of two levers, toothed dropouts and toothed gears on the axles. The Paris-Roubaix is so named because Fausto Coppi won the namesake race in 1950 using this system. The Paris-Roubaix or una leve (single lever) shifter combined the action of both levers into one with the addition of a locking gear at the bottom of the shifter. Notice the part that guides the chain to shift which I call a 'stirrup' is closed on the Cambio Corsa bikes and requires the chain to be broken in order to remove the bottom lever. The stirrup on the Paris-Roubaix is open at the top. These levers are not interchangeable between the two systems.
Cambio Corsa
Paris-Roubaix
How they work; the top lever is flipped out to release the hub in the dropouts. The teeth in the dropouts and the toothed gear on the axle kept the wheel aligned in the dropouts. The rider then pedals backwards and uses the second lever which has a stirrup around the chain and guides it on to the proper sprocket. The rider then has to lock the top lever back into position before pedaling forward. The Paris-Roubaix operates the same way. Even the top riders of the day that used this system didn't care for it too much and tried to limit shifting. If you try to pedal forward before locking the rear wheel at best you jump the chain and at worst you jerk the rear wheel out of the dropouts. This video shows how it works.
Cambio Corsa
Paris-Roubaix
