Hi, all, attempting my first ever rebuild of a coaster brake hub. Challenging! Had to chase the axle threads cuz they were buggered. It is a Perry B-100. It came disassembled in a coffee can, with a 1960-ish Rollfast i picked up. The bearing cages were cracked, and couldnt match them at LBS, so i replaced bearings sans cages. Not sure if that is advisable or not? Anyhow, i have it 90% back together, but the non-drive side dust cap is loose (has play). RJ the bike guy has a great video on this, but his brake arm has a square hole and fits over the brake cone square end, holding the dust cap tight. My brake arm has a small round hole and does not touch the dust cap at all. Thought about a large washer as a spacer, but then would not be able to hold the brake cone square end to tighten things up. What is the interface supposed to be between the brake cone square end and a small round hole brake arm? And what is supposed to hold the dust cap tight in this configuration? Thanks for any help!
