Persons Schwinn Stingray Early Stingray Polo Seat Seats
$145 Each
Cash at pickup or Paypal F&F
San Jose
mike1117
Prefer pick up from me in San Jose, CA only. If you need it shipped I could put a single one of these seats in a flat rate priority mail shipping box as it is for $20 for one seat. Seats were purchased with the intent to recover them. Clamps are on there good. Do not look to have been drilled for rear seat tags. $145 each, $280 for the pair. If you are local and can come for these perhaps we can do some trading for Stingray parts you may have. I am keeping a few others of these pans in case someday I need to have one recovered.
Mike, Persons supplied this same seat to many bike brands. The solo polo seats used by Schwinn for the Stingrays had a white paper sticker/decal on the pan and all were drilled with Persons tags riveted on the rear. The seats used by other brands didn't have the sticker but had Persons stamped in the rear of the pan like yours. Some of these used by other brands had riveted tags while others did not. They are all the same seat/pans from Persons but that is why yours don't have tags. Half of my Stingrays with recovered seats have the stamping while the other half do not, but all have tags riveted on as part of the seat restoration - GLWS
Thanks. Right. You are correct and thanks for clarifying that these pans did not come on a Stingray when they were new seats as there are no holes drilled for the seat tags. The Persons Worcester Mass metal tags. These pans are the same pans used on the Stingrays and some of the other brand bikes. These would be to restore then recover most likely. One could get one of the Reproduction Persons Worcester Mass tags and perhaps even the white reproduction one rider at a time sticker with red lettering for the pan bottom on Ebay perhaps. The Persons tags were even a bit different around the rivets for the early Stingrays if I remember correctly.
yep, that's what I said, agree
The paper pan stickers and the Persons tags/rivets are readily available. The very early 63 Stingray used a "dog ear" Persons tag for a short run, then the more common rectangular tag for the duration
You have good seats there to restore for sure
Not all Persons seat pans are created equal. The can be a huge difference between pans in the location of the sissy bar holes. Some have the holes closer the back of the seat than others allowing them to fit sissy bars of a different widths. The wrong one will never fit a Stingray sissy properly.
All the polo pans like these I have had seem to be the same, the banana seat pans maybe are different. These polo pans were used on the early Stingray with the square back axle mount struts. I have had non Persons banana seats that are way off and like you said do not fit a seat strut off a Stingray. Thanks.
All of the Persons Solo Polo seats I have on and off bikes, probably 2 dozen now, and those I've ever had fit inside the square back Persons struts used on 63-64 Stingrays. That is both the originals for Stingrays with the white pan sticker and the Persons pan stamped version used by other brands. I have seen some variation in the gaps between the seats and the struts, but the Q bolt holes are all in the same general location, albeit I've never felt the need to measure them
