Alright guys I have a problem here I cleaned the contacts new bulb fresh batteries and nothing when I flip the switch, do I have a bad switch maybe? I just cleaned a rusted corroded and nasty batwing light and got it working like a charm but not this one on the Phantom, I can make it work by grounding it off the back of the light to the fender but it wont work using the switch, I figure one of the experts here have ran across this, this is my first Schwinn light so I'm a little in the dark on them, get it? Any way I usually can get any light to work I about an hour but not this one, I can force it to work by grounding it out on the fender, that's why I'm leaning towards it being a switch, but I could be wrong, i took alot of pics so you guys can have a look at what I am seeing, any help? As always I appreciate it in advance!
Aaron
Aaron, I don't know what your grounding to the fender; you must start @ A and go to Z to find the open, with out missing a space, do not pass go, do not collect $200. Your battery + connection touches the bulb B+ directly, and what you described does tell me your good there. Let's work on the '-' circuit. One end of your jumper wire touching the spring curl that touches battery '-' and the other end touching the outside of bulb socket (where bulb is screwed into the socket)… lamp works? if so you have good joint between spring curl and battery; and, also between bulb and holder. We will then continue with our jumper touching the spring curl for several steps, and we will place the other end of the jumper on the vertical piece of steel that holds the bulb socket (don't touch the socket). Do we still get a light? If so, then move 'the other end' of jumper to the rivet that holds the vertical piece of steel that supports lamp socket to the battery holder. Got a light? Touch 'the other end' to the side of the battery holder? Got a light? Touch 'the other end' to the inner pan of the fender. Got a light?
Do these and message me back. When all of these above work, then we must do checks with our jumper from the spring curl thru the insulator (fiber washer) to the clip where switch wire goes; and, our fixed jumper position will be the light bulb socket. We will check the spring curl rivet that the switch wire clip connects to; We will check the clip that switch wire connects to.
When all these work, answer back, & we will work on our switch... pappy
