Pierce shaft-drive question.
bike
6,678
Bicycleland
Replaceable if you can find one-Nice wallhanger if you can get it at that price
Front fork looks bent as well
gkeep
Jun 11, 2014
763
Alameda, CA
I'm no expert by a long shot but it seems like a good deal.
Was it rear ended? Those can probably be heated and reformed. The forks look bent too from a collision, not unusual with old bikes. My Pierce had S shaped forks when I found it. Good luck.
KansasJack
59
Ryderwood, United States
Yeah, I noticed the forks as well. I’m not sure if I’ll put a bid on it yet. I’m afraid it might be more work than I’m willing to spend money on. The seat stay issue might be a deal-breaker, plus one of the auction pics also shows missing screws in the crank housing.
Reactions: piercer_99
Motoguzzipaul
Oct 23, 2009
125
Gregory Michigan, United States
is this a Hygenic Cushion rear suspension
I can not open any attachments to see
if so I have a spare rear fork
1088820
olderthandirt
Jun 15, 2012
506
pilot mt n.c.
use the body shop dent puller that welds a short rod onto the metal after you have cleaned it down to the bare metal you will need to heat the tube up to glowing state then i would use my dent puller to slide hammer the tubes back into as close to a round shape as i could get it then tap it back round with a body hammer .you will need to repeat this process as many times as needed its time consuming work so do not be in a hurry first thing any good tool and die maker learns is patience before anything else <ps try to keep all your fingers >
