Poor Man's Fender Roller
TR6SC
1,160
68
Eureka, CA
Nothing ultra-techno to be found here, but a couple radii to pound against for that fender that needs a little "attitude adjustment."
I used a hole saw which is about as thick as a fender. The slots in the round leave clearance for the edge roll.
The blocks can be used as a set, or either one can be mounted in a vise and used with a soft hammer.
TR6SC
1,160
68
Eureka, CA
Couple clamps, two reshaped Home Depot casters.
Nicely done Zep! Did you shape the casters on a lathe? Or in a drill press? Free hand with a grinder? It's a very good looking set-up.
Reactions: stezell
39zep
Oct 10, 2007
421
Mission Viejo, United States
I’m pretty simple. I chucked the caster in a hand drill. Spun the caster up against my disk sander and shaped different wheels.
The unintended benefit of using the Jorgensen clamp was being able to change the angle of the wheel. I could make it pinch down on either side of the main wheel which allowed me to be able to go right up against an edge seam or right up to the peak of a Roadmaster fender.
TR6SC
1,160
68
Eureka, CA
Thanks for sharing this bit of home grown genius.
WES PINCHOT
2,978
CHICAGO AREA
BACK IN THE DAY (30 YEARS) THE COLLECTORS MADE MANDRILLS , BOTH MALE AND FEMALE THAT WERE CURVED IN BOTH THE WIDTH AND LENGTH TO THE SHAPE OF THE FENDERS. THEY WERE MOLDS MADE OF PLASTIC AND/OR WOOD!
Reactions: TR6SC
mazdaflyer
Feb 16, 2010
562
Mid-West
Very good genius budget ideas...I’m taking notes for the future.
Reactions: TR6SC
Rivnut
1,385
Shawnee, United States
I just worked on a set of peaked Roadmaster fenders with a hammer from my body and fender set and a bag of playground sand. The sand is moist enough and in a bag so that it doesn't shift easily. The hammer has just the right curve so that when the dent is out, the hammer head fits against the rest of the fender and you can't go too far. If the dent is on the rolled edge, a little bit of spot putty works well.
