Pork Chop Drum Fitted To A ‘40 DX with Ashtabula Fork.
Mack the fork
I was hoping to find a Schwinn script high flange hub to mate to my ‘40 DX project.
Having grown impatient with the search for a Schwinn high flang hub, I’ve changed course with the unexpected acquisition of a Pork Chop/ High Flange front drum set up.
The problem is that the Pork Chop axle is a larger diameter than the dropouts on the ashtabula fork ( 3/8”) , and the
Brake arm clamp is designed for a round, tubular springer fork leg , not an ashtabula blade type leg .
Now, I understand that these are not insurmountable modifications.
However , if someone has already done this, I’d like to hear about any tricks to get everything properly aligned and fabricated.
I was thinking of using a hydraulic press to press and pinch a piece of thin bar stock that’s been wrapped around the fork blade; to get a tight, form fit. Then file and drill it to its final shape.
As far as drilling and filing the fork dropouts to accept the larger axle; what method(s) have you Cabers used to ensure symmetry and correct orientation of the axle and wheel ?
Use a coaster brake clamp for the clamp, and just dremel out the dropouts a touch wider than the axle so the have room to seat right. You don’t need to go crazy with the clamp cause the brake won’t be very strong anyways lol
I have some experience with this. The fork legs can be easily clearanced with a rotory type tool or file. I used a die grinder with a carbide bit. It doesn't need much removed. As far as the clamp, I didn't have any luck modifying the springer style round one because of the thickness. I ended up using some vintage wald basket clamps and slowly shaped them to my fork. I lined it with dense foam to protect the fork paint. I know other cabers have made them from scratch with sheetmetal.
1434537
1434538
1434539
Thanks Cooper!
If you don’t want to file the dropouts bigger use can actually file a flat spot on each side of the axle where it sits in the dropouts. The threads will still work. I’ve seen stock axles like that.
