Pre-1910 Iver Johnson
Otis in Mayberry
On Training Wheels
Mar 25, 2018
5
11
49
Bayport, NY, USA
#1
Hello! I’m new here and need some advice. I recently acquired my first vintage bicycle, a pre-1910 Iver Johnson in totally rusty condition. It spent many decades in my neighbor’s leaky garage. I’m dating it based on the Iver Johnson thread here on the Cabe that uses serial numbers. Looks like 180203. The bicycle appears to be all original and solid, and the pedals crank easily. Spokes are rusty but seem strong. There is no brake, coaster or otherwise. The front tire is missing the tube. 26” tires. Believe it or not, the bell actually rings, in a rusty sort of way. The handlebar grip are wood.
I guess my question is, what do I do? Is it ok to wire brush it?
I’d appreciate any and all advice. Thanks!
ivrjhnsn
1,229
1,877
Fitchburg ,MA
#2
Do nothing to it.. If that rolls, it's cool .. The rims are not original, rear hub may be. But tires will be easy to find. Some type of rusty bolt solution is in order. Just spray it down.
Nice ! :D
eddie_bravo
Jan 21, 2015
599
1,891
48
Garden Grove
#4
That’s a rider
Agreed with updating the wheels and a new chain
WD40 the frame and ride it , rust and all!
Eddie Bravo
John D. Williams
68
29
#6
Hi. I've seen this bike up close and have some questions. The rear hub is a fixie; is this stock? The tires are clinchers. I am guessing the original rims were wood and the tires were glue-on, but the wheels warped and newer ones were re-laced to the hubs. The owner is inquiring about tires; where would these be found? They say 26 x 1 3/8.
Would it be proper to wirebrush this bike, heavily except for the spokes, and then lube it to ride? I am concerned with the spoke strength.
Rambler
Nov 1, 2011
677
447
Auburn Hills, United States
#8
A couple issues you may need to address if you hope to put this bike back on the road. Appears that sprocket is rubbing the frame which could mean issues with crank bearings, cups, or cones, and there also appears that there may be a crack in the chain stay.
dnc1
1,642
4,104
52
Wallingford, Oxfordshire, UK
#10
Even if that is a crack, it's easily repairable.
I would rub down with wire wool and WD40, get new tyres, sort out the bearings and ride it; as far and as fast as you dare!
Enjoy!
Likes: tripple3
bricycle
Nov 18, 2009
21,283
6,000
Chicago area west
#11
Hi Otis! -Welcome to our group!
as crusty as the two reflectors may seem, they are probably worth some decent bread.
If you wana ride her, find a pr of 28" Raleigh wheels for her, or a pr of 700 series wheels/tires. Or of $$ not an object a pair of Noah Stutzman wood wheels.
Likes: filmonger
Otis in Mayberry
On Training Wheels
Mar 25, 2018
5
11
49
Bayport, NY, USA
#12
Hi All,
Thank you for taking the time to look at the many photos and your advice about the IJ. I’m not sure if that’s a crack, but if it is it is very tight and not deep, which I guess is good. Please see the additional pictures.
My friend John Williams (who posted above) and I will look it over better. I’m ignorant as to most of this stuff but have learned a lot from John and just reading through different threads here.
What about using the current rims, even though not original? What tires would I need? Would the spokes be strong enough?
John D. Williams
68
29
#14
Hi everyone. I have taken apart this IJ. There is no frame crack and the crank is not rubbing as it turns out. The serial number is 150268, I have found some info on this on CABE. The owner thinks 1905. Any opinions? It is cleaning up well. I need to know what kind of tires to buy, will any 26 x 1 3/8 non-Schwinn tires fit these rims? And I may have some upcoming questions about taking apart the crank....
Duchess
Feb 14, 2014
510
897
Beverly, MA
#15
Maybe I'm not seeing it right, but the chainring teeth look really worn to me as far as riding goes. The serial number on mine that I peg at around 1912 is 195xxx however that might help.
John D. Williams
68
29
#16
The chainring looks okay up close; we will test the bike carefully (I am 145 pounds, Frank's over 200). It's a fixie with no auxiliary brake, so it has to be ridden carefully. I did a nuts and bolts cleaning, and am putting it back together. The rear tire is really on there, and I'm not able to budge it with any kind of lever
... pics attached so far--
Duchess
Feb 14, 2014
510
897
Beverly, MA
#17
The teeth on the chainring should look like flat top pyramids in profile, so if it's to be ridden for appreciable distances, you'll probably want to get another chainring. Cleaning up really nice, though! Does the rear tire hold air?
John D. Williams
68
29
#18
Yes the tire holds air. It will not come off the rim, and we want to replace both tires with white period-looking ones. Not sure what to do.
Duchess
Feb 14, 2014
510
897
Beverly, MA
#19
I'm not sure how to remove it without destroying it. May be the only way if it's metal bead clincher and the rubber deteriorated, leaving the bead to rust to the rim. There may be a better product than I can think of, but if you can get a good liquid penetrant, spray around where the tire and rim joins, leave it overnight (maybe hitting it another time or two), then get some sturdy picks or whatever can get in there to work the rubber and metal off. This method worked pretty well on rubber engine hoses in a marine environment, so maybe it would help here.
Likes: dnc1
GiovanniLiCalsi
3,072
842
Alameda, California
#20
The chainring looks okay up close; we will test the bike carefully (I am 145 pounds, Frank's over 200). It's a fixie with no auxiliary brake, so it has to be ridden carefully. I did a nuts and bolts cleaning, and am putting it back together. The rear tire is really on there, and I'm not able to budge it with any kind of lever View attachment 782388 ... pics attached so far--
You can use a snowflake chainring, too
