Freqman1
In the for sale section is a '41 DX with a springer that has the fork stop on the downtube but pretty close to the headtube. I have a '39 DX springer that also has the fork stop. The fork stop is a small metal tube welded to teh frame with little rubber bumpers on each end of the tube. If you go to the home page of this site you will see a link to Schwinn serial #s. Also contained in this link is info on determining frame dating by year. Under the heading "Telltale Frame Designs (4.) it says "1941 Deluxe had a a metal tube welded onto the headtube to protect the tank from being dented by the springer. 1941 was the ONLY year for this."
So a few of questions here. First is the Deluxe being referred to an Autocycle or is this any 'deluxe' frame? Second if it is a cantilever frame is this fork stop actually on the headtube or is it on the downtube? Next if this reference was strictly for the cantilever frame then when were these put on DXs? Were they ever put on straight bars? I would surmise they were put on DXs starting with the first ones in '39 and running through '41 (springers only). I recently sold a '39 DX bare frame and it did not have the fork stop so did Schwinn run these in batches? It would be interesting to see the serial # correlation regarding this. OK I'm done, your turn! v/r Shawn
