Nashman
Good day all. I am looking for a parts break down and sequence of parts application ( picture if possible) for a pre-war Schwinn rear brake. This would be from the inside of the drum moving out ( left side of course) from the race with balls and grease, dust cap, cone ( that's a given) to after the cone to the final axle nut. There are obviously the fender braces and rack legs and a series of washers ( what type washers/what order?) and a lock nut? I've had some help from Cabers/pals so far, but would like a reference for now and future folks to use.
I have had the misfortune of my 1941 Autocycle's axle locking up and making a mess of things. The cone spun SUPER tight into the race dust cap. The rear wheel was literally seized. Then the right axle/freewheel side spun undoing the end nut. Sheesh!!
Taking the fender braces, rack legs, backing off axle/chain adjusters, pork chop anchor bolt, chain off, nuts, washers over and over is a chore, especially on a fresh resto. All in the fun of bike mechanics, eh?
At one point the axle was so tight the spoke ends at drum outside were brushing the pork chop...Yikes!! I placed a large flat washer after the cone ( after loosening) to create a spacer, but after some tips and tricks, I see there is a knurled/serrated lock washer of sorts ( a friend sent me a picture of his washer) with a D hole ( see pic) that likely goes against the cone. Apparently there is a thin lock nut to come into play as well, perhaps outside the porkchop?
I have the wheel spinning freely now ( on and off multiple times) and kept the cones a bit on the loose side, but fear ( I won't be riding this much/mainly a show piece/display) a repeat situation if the bike is ridden, will never be hidden. Mechanically, I've wrenched on dozens after dozens of bikes, cars, motorcycles, boats, scooters, wagons, you name it. Jack of all trades, master on none. I "get by". I'm never too proud to ask for help. If I can put something upside down, backwards, or topsy turvey, I usually will 1st, then 2nd, 3 time is usually a charm.
Thanks/see pics/ Bob
