Rear hub, should have lock nut (beyond the cone, inside the frame) and 2 stacked washers, one larger serated and one smooth sided, slightly smaller, then the axle nuts. That's New Departure by the way. Same goes for Morrow and Bendix only One washer per side.
Fronts vary depending on the hub and axle set up, but one washer per side.usually suffices
