mr.cycleplane
Riding my Motorbike
Offered here is the 1936 Schwinn stem-known as the true razor. so named for its three crisp peaked ridges on the stem bridge. this stem is the first year and made from brass. note: the 'v' on the front of the stem above the pinch nut was only found on these brass first versions. this stem has seen some use and light abuse(wear to chrome from use and abuse from improper removal-see the small dings along top). also has '4191' number stamped on top-see picture. hard item to find-correct for the higher end prewar Schwinns.
