The picture looks much better than in person. The paint was orig. yes, but rusted thru in many places. The fenders were very bad, many little dents, welds. patches, etc. The fenders now on the Whiz are NOS from a 47 or 48 Schwinn 26" cruiser. So basically the are the exact fenders the came with the orig bike (minus the cut out for the light, which I didn't like anyway). By the way the old schwinn fenders are 4" wide. These fenders are very hard to find NOS in original primer. The seat is a real orig. charmer. I polished it and recovered it in orig. tan leather. It came out very nice. The orig. owner had to slice the frame to fit the engine. The motor mounts used were real old orig. 1939, early 40's type mounts whizzer used for those years. They lift the engine a little higher than the later mounts. Apparently this was the reason the lower straight bar was cut. I had two supports welded in place to add extra strength. Not very noticeable when everything is assembled. The serial no. (E37115) was researched and the Schwinn Excelsior was built in 9/10/1948. If anyone has ever drove a Whizzer without a front suspension, you bounce around this so much it isn't pleasant to ride any periods of time. Then you'll know why I switched to an original early 1949 schwinn springer. I was told that some of these models could be ordered with the springer. So I'm trying to keep most everything original and only use orig. schwinn parts for that era, circa 1948. Thanks for the interest. I'll keep you posted.
