Prewar stuff for sale (frequent additions so keep looking)
Got a couple of these prewar headlights. Each has remnants of a bracket but definitely need work for proper mounting. I have not tested the bulbs, but the filaments look fine. The are likely original bulbs or at least very old. The fronts of the bulbs have a swirl pattern in the glass. The one on the left has more of a bracket, just needs a plate with a curve to fit the bars and a hole to bolt it to the plate that is there. But it also has a few light scratches on the lense and a small crack in the collar where the wiring plugs in. The one on the right has no scratches on the lense that I can detect, and is generally a little nicer. Either one has a bracket clamped to the collar that could be used to bolt it to just about any bracket you have laying around. The one on the left, $65 shipped. The one on the right is $85 shipped
Klaxon style horn. It is loud and annoying, but not sure if it is as loud as it should be. It is a little smaller than my other klaxons by about 1/2" each way. Might need adjusted. Not really sure. Either way $80 shipped
1920's Crossbrace bars, pitted, patinad, whatever you want to call it. They are just a solid set of rider bars for a patina bicycle. They are 19 1/4" wide, and have the hole in the left side so are probably Torringtons. Stem included. $110 shipped
This is a cool prewar rack. Has the spring-loaded parcel retainers. But also has a front extension bracket and the braces are screwed to each other instead of riveted. This way you can adjust them to fit any bicycle. I don't have the two screws to install the front extension. I will remove the brace screws to pack and ship cheaper, and will bag and tape the screws to the rack. $70 shipped
35-36 Schwinn dropstand with ears. Should fit just about any 26" bicycle though. Ears have the slightest bit of looseness. But they are still very tight, no signs of failing.
$95 shipped
