What do you need left and what did you use the parts bikes for other than rear hub?
What do I need left? That's a good question.
I think I have all the parts to do the bicycle in budget, ish. I wouldn't say "no" to a trade for period-styled grips or a period front axle, but given that I don't know who made the front axle as of yet, that seems a moot point.
I suspect that once I have the bicycle moving, that a certain number of little things will break and will have to be dealt with.
The biggest thing I need at the moment is data. I haven't found period literature that shows a bicycle with the same frame, paint scheme, and fenders. Once I have that, moving forward with any missing pieces will be easier.
I know, at present, that the frame is physically different from the one illustrated in the 1920, 1921, and 1922 Montgomery Ward catalogs. (They do, however, The 1916 and 1917 Montgomery Ward catalogs have the same frame and many details, but the paint is a solid color and the fork is different. The 1932 catalog shows a similar frame, but the fenders are wrong.
If not for the single brace between the bottom tube and the top tube, and the different color, I would say that
this 1921 Hawthorne is the closest match. The headbadge matches, as does the seat. The paint scheme is identical, but in a different color. The fork appears the same. The sprocket, however, appears to be a Schwinn one, rather than the Snyder / Harris one on my bike. The fenders are almost the same, save that the front in the catalog has a mud flap. If I could learn more, I could do a better job of getting the bike back on the road as it was.
As for parts used:
- pedals
- grips
- axles front and rear
- frame pieces to make drop stand and brackets
- all sorts of hardware for assembly
- minor brackets
- all those little $10 things that add up when you don't have a parts stash.
I had planned to use the tires, wheels, and spokes, but then a bicycle with 700c wheels came up cheap, and I could not resist. However, if I cannot sell enough off of said bike to bring the costs down to zero, I may have to resort to using the wheels from the parts bikes. Further, I had planned to use a stem from one of the bikes, but I'm thinking now that the existing one is more correct.
