Sold Rare 1939 Hawthorne 5 bar project will ship or local P/U in RI
$650 shipped
Ashaway RI
bikesnbuses
Good spring project..Ill likely never get to it..I collected a few parts for it since I got it..NOTE: I DO have NOS chain adjusters and nice Diamond chain to go with it. I don't have bars for it I believe, seat..I don't have a correct one for it sorry..
I believe this bike was black/cream originally
The rack (blue originally with wrong reflector)and chain guard was purchased afterwards(The chainguard needs the front frame bracket "loop" made smaller/correct..I do have the truss bracket and bolts here
The crank chrome is decent,I removed the paint on some of it to show that
IF you buy this locally for cash,I have a set of wheels for it,otherwise I dont feel the wheels I have are worth the value of the raised shipping cost that they will add,I also may have a correct stem for it
The headlight is very strong and solid BUT has holes in the bottom that dont flex..without guts inside ..I planned on doing a LED light conversion for it..
It also comes with replacement fender braces(Only 1 need replacement I believe)
The crank at some point apparently came loose (as it doesnt look bent) and gouged the frame a little which I had welded instead of just using filler on it.. I sanded down the paint on the upper tube to confirm that this is NOT a Zep..(No tank holes)
$500 CASH local pick up in southern RI
$650 shipped in the USA
OR TRADE for/toward parts I NEED.. links below;
