Rear high flange forebrake question...
BFGforme
riding a'41 BF Goodrich deluxe autocycle deluxe
Nov 28, 2016
2,017
49
Oceanside CA
Hello, I recently purchased a front end rear fore brakes! Question is the rear sprocket, it's 16 tooth and like always riding uphill! Wondering if there is other options for sprockets, does other brands work or schwinn only? Anyone have a 20-22 tooth sprocket that will work on this hub? Wanted to ask here first before I post in wanted section... thanks for your knowledge...
1817cent
Oct 18, 2016
457
Ellensburg Washington
Will be curious what you find out. I have 2 bikes with the rear hub like yours and have the same problem.
Reactions: BFGforme
Sep 2, 2012
12,001
Central Arizona
From Schwinn lit that I've seen, they only offered a 16-17 and 18 tooth freewheel sprocket.
Reactions: BFGforme
BFGforme
Nov 28, 2016
2,017
49
Oceanside CA
Then guess I'd like to find an 18 tooth.....
BFGforme
Nov 28, 2016
2,017
49
Oceanside CA
What I'm hearing is most common on'40-41 was 20 tooth sprockets and used commonly into post war also....so someone should have some.... here's example...
Let me know if have one???
bobcycles
4,798
13
so cal beaches
No idea where you would have heard 20 tooth were common....bogus info...
very tough finding anything substantial...most are 16--18
Reactions: BFGforme
Autocycleplane
2,182
NorCal, United States
16, 17, 18 freewheels were offered on the early 38-39 dural rear hub. I think other period euro freewheels fit and come in other sizes.
14, 16, 18, and 20 (8 & 10 1" pitch too) rear cogs were offered on the later 40+ drum (like you have pictured above) that used a proprietary freehub assembly. It shares that assembly with the same period large flange rear hubs, so one of those might be a source for the 20 you seek.
Here is a set of '40 BA Special wheels, you can see the 20t on the rear.
BFGforme
Nov 28, 2016
2,017
49
Oceanside CA
I also meant to say common on'40-41 autocycles had the 20 tooth, lightweights had the smaller ones, racer, track bikes etc....
BFGforme
Nov 28, 2016
2,017
49
Oceanside CA
Anyone know of any other sprockets that might work on this? At the moment my only rideable bike and it's wreaking my knees! Thanks in advance.....
BFGforme
Nov 28, 2016
2,017
49
Oceanside CA
If you mean smaller front sprocket on crank? I can't it cost to be cool... even if it means blowing out knees, then......weeeellll
BFGforme
Nov 28, 2016
2,017
49
Oceanside CA
Adjusting barrels for the brakes arriving today! Now just need a sprocket, or bunch of hills to ride down! Lmao! Please someone has to have a stash....
prewarkid
Oct 26, 2010
220
714 Baby!
I had one of these before and I removed the cog from hub and took them it into a bike shop. Bike shop owner looked at it and handed a 20 tooth cog, thread right on and worked like a charm. Cant remember the brand but I remember it was for a BMX.
Reactions: BFGforme
Cooper S.
Aug 28, 2016
832
27
New Lenox Illinois
You could get the smaller 46 prewar clover style sprocket instead of the big 52 tooth
