Where can I get a rear rack for my 1963 Racer? I want one with the spring in it but it does not have to be vintage. I’ve checked on Amazon, but trust you all here a great deal more.
So, I have found some of the Pletscher Bike Racks on ebay. I need to know which one fits my '63 Racer. I got one only to find out the bottom mounts are too wide. I could possibly find longer screws, but the rack mount covers up the fender mount and looks a bit awkward. I need one that has a mount that comes from the rear and to the fender mount screw and with a hole that is not super wide...or I just
NICE Racer, love the black!
Longer bolts attached at the fender eyelet would work if you want to keep the Pletscher but the rack legs are so long that the rack doesn’t sit level. I think either your rack was designed for a 27” wheeled 10 speed or, if possible, the front support needs to be mounted higher up on the seat stays (closer to the seat) to sit level. If you don’t care about it being level use the longer bolts.
Schwinn started selling accessory carriers in the1965 catalog. Below is a good pic from the ‘66 catalog of the early carriers. The top one was designed for middleweights; the leg length would fit your 26” lightweight but may be to wide at the bottom. It has a spring holder.
I think the “correct” rack for your lightweight Racer would have been the bottom rack, but it doesn’t have a spring clamp on top.
BroCraig:
It's easy. You need a T bracket to keep the rack from slipping. Go to forum on lightweight Schwinn bicycles and see the thread on rack/carrier question for pictures of brackets and typical installations. If your rack didn't come with a bracket, they are easily fabricated.
