Repairing pedals
Deebo
Can these be overhauled? K10490 thanks.
here's a tip , if the pedal block pins have removable nuts you can service the pedals
If the block pins have snap rings on the pins or a back plate that grips the block you can't service the pedal , with a few exceptions
try aerosol can of white lithium grease. it will weep in the nooks and crannies, should reach the bearings.
Thanks bro. I thought of wd40 but it will eventually evaporate. I'll do what u said.
