I've got a few methods, with different levels of damage.
Least damaging is take a flat head screwdriver and stab it between the block and the outer plate, to hopefully pinch the bolt and keep it from turning. If you tweak the plate a bit you can usually hammer it back straight.
Most damaging methods are vice grips on the head of the pin. If the pin is loose and comes off, you can grind and polish the vice grip marks off.
Or, if you don't plan on saving the old blocks, grind or cut the block in the middle, taking out a chunk big enough to grab the pin in the middle with vice grips, so you won't see the damage when you put the new blocks on.
If you can get a cordless impact gun, that'll usually spin the nut off with no damage.
You can also cut the nut off carefully so you don't damage the threads on the pin, and replace the nut.
Or just buy some better pedals and save the old ones for a crusty rider.
