Now that all the machining was done, it was time to assemble it. I made a jig to locate each sub assembly so I could silver solder the splitter junction
I used the original assembly to fit some aluminum angle that I machined, then mounted each piece to a plastic base.
You can see the cable junction that needs to be exposed for soldering
Original sample. Note steel plate between angles protecting plastic from brazing torch.
Cloned replacement
