rustystone2112
No sign of life yesterday when I got it. After removing the wasp nest inside and cleaning all battery & bulb contacts still no sign of life. Take the switch apart stretch the spring a little , clean contacts , add a little dot of solder on each bump on the brass switch plate to build them up due to ware, reassemble, switch works still no life. Re-solder all wire connections, Tail light works no brake light. Re-solder a sneaky little ground connection the brake light shares with tail light, RESURRECTED!!!!!!. Now anyone know where to find a lens
