Retrospect 65
68_STINGRAY
Aug 17, 2010
113
11
#1
Circus act
I had decided to start another build, I started by looking on Ebay for a 60-69 Schwinn Stingray frame that i could start my design on, to my surprise i found a 1965 Stingray for 79$. What made this frame unique from the others was it had a raked neck, which i was planning on doing to the frame i bought any way's, so that made this build a little more easy and less expensive. I have a speedo with original chrome, it has pitting on it so i may have it replated,My plan's are to have it engraved and replated and much more. For now i will leave you with photo's of the bike frame it's self and a mock up to show how low and slick it look's.
68_STINGRAY
Aug 17, 2010
113
11
#2
So today i already started working on the frame by cutting the added brake cable clip's off and started smoothing out the area were i cut them off. I pulled out my die set ready so i can put a thread into the hole that bolt's the rear fender on, Im doing this so i can finesh capping off the area behind the seat post and still bolt the rear fender in place.
Mask to protect my lung's.
Uploaded with ImageShack.us
and let's not forget the goggles to protect my eye's.
68_STINGRAY
Aug 17, 2010
113
11
#4
Started removing the clip's, on a side note, for you young guy's/girl's that might read this thread and follow my build, use protective gloves when working a grinder, if it is your first time working one dont attempt to hold it with one hand, it is very dangerious and can cause injury. (((YOU HAVE BEEN WARNED)))
photo sharing
68_STINGRAY
Aug 17, 2010
113
11
#6
Today we reaceved the propper saw's and other tool's we need so i can continue cutting off the added licence plate clip on the left side of the frame near the drop out's.
sam
1,428
412
San Antonio, United States
#7
Lookin good.I usually stop with the grinder just before removing all the tab and finish up with a large(or med.)hand file.Makes for a smoother finish and a good sharp file works fast too.
also you might want to double check the clearance those forks have against the tank---hitting the tank was a common problem on the phantoms.If a problem you might widen the forks and add a wider tires too,for the old school look that's getting popular with motorcycles.
68_STINGRAY
Aug 17, 2010
113
11
#8
Thank you for the advice Sam, the clearance i have been looking into. In the mock up photo i took, i actually hadn't put the bearing cup's or bearing's in, on the grinder i didn't have a file on hand to use on this, but i cleaned up the bar's today, which i will be posting up shortly.:cool:
Here is a close up of the mock up from the other day.
68_STINGRAY
Aug 17, 2010
113
11
#9
So today i went to the depo and picked up a new grinder because two thing's acured during working on the frame today, one the cord accedently caught the grinsing wheel and took a chunk from the cord, and to make thing's worse, the grinder stopped working while i was cutting the other clip off.
The ugly added license plate clip.
The old grinder R.I.P
photo sharing websites
The knoch cut in the cord.
68_STINGRAY
Aug 17, 2010
113
11
#15
Using the 4 1/2 grinding wheel once again, i cut the tube entirly through one side and 90 percent of the way through the other side, being carful not to cut off the chain guard mount clip.
pic upload
I gently pushed the tube out ward's to break it the rest of the way out.
host images
68_STINGRAY
Aug 17, 2010
113
11
#19
The out come of what i did this evening, notice the nub on the top side of the seat tube removal, i am leaving that as is until i can finish the capping behind the tube and cover the bottom of the tank and top of the crank housing.
photo storage
68_STINGRAY
Aug 17, 2010
113
11
#20
I'll end off tonight's fun by leaving you with a pic of my wall of Schwinn's. :cool:
Junior 68 Stingray , 79 Stingray ,71 Fair lady , 65 Stingray
photo storage
Until next time.:cool:
