FICHT 150
I’ve owned perhaps a dozen of these hubs over the years, and while the adjustment can be a bit finicky, they have been serviceable and reliable hubs for me over the decades. I had one that had a slip in ultra low gear, and I could never chase the slip away. A slip in this gear is disconcerting, to say the least, while trying to muscle up a certain hill we are familiar with. The factory instructions gave a few culprits to check, I dutifully pursued them all and really got nowhere.
Turns out the factory forgot one.
Notice the two sun gears in the photo posted. The sun for an S5 usually has small ramps cut in the top of the lugs, to speed engagement with the corresponding gear, for lack of a better term, on the axle. This particular sun was machined with the entire lug as a ramp, which, is going to make it damn hard for it to be solidly engaged with the axle.
The other sun gear is the slightly different part number that is used in an S5/2 hub, and, perhaps, others. I knew it was in a homeless hub I had on hand. If there are folk that seek out and run S5/2 hubs, I’ve yet to meet them.
My guess is they quit machining the ramps to save a step in the process, but, who knows? I removed the offending part, and installed the newly harvested S5/2 sun gear. There is no question that it will solidly engage the axle. It might take a fraction of a second longer to do that, but, I don’t see that being an issue.
Full disclosure, the last AW hub I converted to S5 specs, (you need a homeless FW hub to do that) used an identical sun gear that turned up in my parts pile. So, I knew it worked, but, I’d never seen a sun gear that was so clearly defective as the one that came out of this S5 hub. I imagine some kid had a frustrating bike that never worked right.
Ted
Ted
