Fifthcenturycheese
I recently laced a 40/41 hi lo front drum hub in a drop center rim using 10 5/8 or 270mm stainless spokes. Someone on here mentioned you can use the same length spokes for both sides of the hub, being a 4 cross and 3 cross pattern. I'm finding that the lo side of the hub is really close to the inside of the fork, axle is not centered. Any ideas on this would be appreciated, thanks, Mike
