I have not seen any information on frame geometry on the middleweight frames like was common on the highter end lightweight frames. It should not take much to answer your question. Today you have low cost digital angle finders. Heck even some smart phones have an angle finder app. Just level the bike on the ground with some thin spacers to adjust to zero. Then measure the head tube angle and the seat tube angle. Done.
Imo, it's more accurate to measure the tube length's "center to center" to be uniform and consistent in your measurements. Most bicycle companies use the C to C way to measure frames. Schwinn, was odd because they measured their frame sizes from the center of the crank to the top of the seat tube. All of the other tube lengths were measured C to C.
If your really into this, I would make up a gauge tool. Use a 5/16" drill rod available at any industrial hardware store. Then make two pointers if you have a lathe. Drill the pointers with a 5/16" hole for the drill rod, and drill and tap them for a set screw. I would make it four feet long. Just move the pointer until it matches your center to center distance and snug up the screws. It's really handy for measuring frame tube lengths, of chain stay lengths (axle center to crank spindle center).
Keep in mind that it does not matter how many bends or curves the frame tube has in it, it still comes down to the "center to center" length that matters. For example, on a girls frame the top frame bar angles down and is much longer than on a comparable wheel sized men's frame. But the only measurement that has any real meaning to the rider fit and ride quality is the "effective top tube distance" or the center of the seat tube near the seat post clamp to the center of the head tube just below the top head cup. That distance will determine if the rider is comfortable sitting on the seat and reaching the handlebars.
John
