Schwinn Corvette 3 Speed - $360 - Madison WI
rennfaron
"can't get the bolts to budge..." :rolleyes:
Should clean up nice, if you can get the bolts to budge
:p
Gotta love a woman trying to fix up her old Schwinn. Hope she didn't round off all the bolt heads. :tonguewink: What's up with that shifter?
Oilit
Yah, but it's on a 1958 Corvette. I thought the Austrian hubs showed up on the 59 models in third quarter production?
Maybe originally it had a Sturmey-Archer SW that was replaced under warranty? I wonder why they can't get the bolts to budge? I don't see much rust at all, so that's not the problem.
She probably tried to take off a pedal, left side, and couldn't break it loose and gave up. She should have unloosened it. :tonguewink: Note the nylon bolt cap on the front caliper.
rennfaron
When you find nylon nut caps still intact it typically is a good sign. Look how clean the beehive springs are too. The rust on that shifter is not consistent with the wear and rust on the rest of the bike... Could have been swapped out with something later on and the Austrian shifter was pulled from another used bike.
bikepaulie
Thanks for posting! Think this came with struts instead of front rack? No front light, if it was there to begin with. Fenders appear too clean, probably new. Bugs me when sellers shave off the rear fender in the pics so I can’t see the reflector; doesn’t appear to be one.
rollfaster
It’s missing the front rack, clamp still present. Fenders look like the correct stainless ones to me. There would have been a battery operated Delta ball light mounted on the stem.
