Withdrawn Schwinn Expander/Drum brake lot, fronts and rear brakes
California
bobcycles
Schwinn Drum brakes as shown. Rear has some patina on the shell but should clean up ok
Correct nuts with D washer etc. and is correct for Balloon Schwinn bikes.
Brake shoes have some life but one spring is missing, I believe
these have been reproduced and are easy to find. Backing plate has been painted over silver and
is still legible. Free wheel works fine.
Empty shell is sound, but will need plating etc, there are some extra holes drilled for some reason
adjacent to the spoke holes.. Should probably be rechromed
Front complete drum with cable was removed from a Schwinn 50s era Town & Country tandem
it is slightly wider than standard bicycle hubs but will fit most forks ok. Shoes look ok for used
and both springs are there, hub shell is decent but backing plate is very pitted. Cable and lever
were correct for the Town and Country mid 50s bikes, bottom loop of brake lever is missing.
All for the D or ND
Bobcycles@aol.com
or PM Here
1684262
1684263
1684264
