1965 Schwinn King-size Heavy Duty.
SN LA23145. Currently still listed on the registry as owned by Dizzie Problems. I bought the frame set from him.
I bought this here on the CABE as a rough, bare frame in June of 2019. I’d wanted a King-size for years but could never find one. I had been tooling around on an 80’s HD. It was a great bike but I wanted something a bit larger. I bought the frame planning to transfer lots of the good parts from the 80’s model onto the 65. It wasn’t until quarantine that I finally had time to get to work on it.
The frame was pretty rough. It had an worn, dark green re-paint. Lots of the metal was rust-pitted. I think a number plate of some type had previously been welded (and then later cut-off) from the underside of the top tube and there were some nasty looking holes remaining. I first stripped it all to bare metal, welded up the holes and then used body filler on all of the pitting prior to priming and a repaint. The new color wasn’t exactly what I wanted but it was what I could get at the time and I decided to run with it. I then added decals and clear-coated it. I couldn’t find any kind of KS chain guard decal so I went with the HD version and called it close enough.
I do have correct fenders for it but haven’t painted them yet and I’m not even sure they would fit the 2.35” Fat Frank tires I’m running. I have a friend that has a two speed kickback for me and I may end up using that with some 1 3/4” tires in the future. If I do use that I will install the fenders.
I‘m still in the “shake down” stage with it but I’m very happy so far.
