This set up is very interesting. Original hard grease that protected the nickel underneath. I cleaned a small spot on the backside to show potential. I believe underneath this overgreased and hardened gunk this sprocket and cranks would look like amazing survivors if warranted a shiny crank on your bike. I will eventually clean the gunk off if they do not sell as is- just brings the price up. Pedal block are original but the pedal bodies do not match. The lock not for sprocket did not come off easily so I let it soak with thin oil and decided I will let you deal with it. Vice situation I presume. The right pedal is the worse one so the rider set his bike down on the right side and didn't use his dropstand..All you see pictured for now is 330 shipped from Wi.
