schwinn rim widths S-4 ?
looneymatthew
are s4 rims for specific schwinns ? tanndems ect. and what are the differences from s2 rims are they considerd mid weight? S2 2.25 what are s4 ?
Hi Mathew,
The S4 rim is the same as 650B which is a popular size for French tandems and touring bikes, and has recently been used for mountain bikes.The rims are a little bit taller than S2s. The tires are not interchangeable, so you need to buy 650B tires for S4 rims.
thank you
could not find alot of info. thats what i needed to know thanks alot.
Hi Mathew,
  • S4 came on Walter Weights also
the original tires for the S4 rims were 26x1-1/2 " the 650B tires work,but never seem to fit just right.the Schwinn Hurricane 26x1-1/2 tire are still out there.I recently picked up a set for my 53 welterweight.
Tire sizes by Diameter...
S-2 ........... 559 mm (26 x 2.125 / 1.75) Balloon , mountain and middleweight
S-7 ............ 571 mm (26 x 1 3/4 ) Schwinn Middleweight
S-4 ............ 584 mm (26 x 1 1/2 ) 650b / Schwinn Welterweight AND todays new 27.5 tire designation
EA-3 ......... 590 mm (26 x 1 3/8) Lightweight
S-5 / S-6... 597 mm (26 x 1 1/4 - 1 3/8) Schwinn Lightweight (AKA as EA-1)
S5 was intended for 1 3/8" wide tires ( available in 20" 24" and 26" )
S6 was intended for 1 1/4" wide tires ( available in 20" 24" 26" and 27" )
Thanks!
Does anyone know how late Schwinn used the S4 wheels on tandems?
