Schwinn Sales West
I did not know it was an expander hub.At this point with the wheel torn down his options are limited. The hub is an expander brake so messing that up is not an option. I'd get a #8 extractor and an impact wrench and go at it like a crazy monkey in a cage.
You do realize the extractor "only works" after you have removed the axle set. We had one in the shop for "worse case examples". We had to use a cut off wheel to remove the "starter end" of the extractor. That allowed the extractor to fit down into the freewheel body far enough to contact the extractor taper without hitting the hub cup. The exactor is a crude way to remove it, IMO.
I would just respoke the 18 rightside spokes of the wheel, put the freewheel body into a vise, and turn the rim counter clockwise to remove the body. The only hang up would be "if the spokes were already cut". It will unscrew, I have not seen one yet to not come off after you can apply a good hold on it. It takes much more torque to loosen than you can apply from a 10" Cresent Wrench. I would never use an impact wrench for this job.
I'm a (retired) aircooled Volkswagen racing guy (19 years drag racing them with my son). We never used an impact to tighten or loosen the gland bolt holding the flywheel. We used a 36 mm socket and a custom welded four foot long breaker pipe to apply the massive torque to secure the flywheel. A 1/2" impact could only apply about one half the torque required.
John
