Schwinn Streamliner Black and White
oldfart36
1,615
64
Parsons, United States
Winter Project! The old boy (original owner) had kept this bike since his childhood. Years back, he decided to take the bike apart, with the intention of restoring it (thank god he didn't). The bike has sat in boxes for years since then. After his recent passing, his wife thought it was time to let the bike go.
oldfart36
1,615
64
The basket/boxed OG paint 54 Streamliner is coming along slow but sure!
Finally fought off the 65 yearold safety tape!
Trying to keep everything just like it was when original owner took it apart 20 years ago. Thank the lord he never had the chance to start restoring it!
1098743
Uni-Bike Lou
May 20, 2015
117
Hoffman Estates, IL
Is that chainring common for 54 Schwinn’s?
I see a lot of chainrings with the 4 circles.
The reason why I’m asking is that I’m working on Streamliner that is a 1954 or 1956. I want the correct chainring. If anyone could help that would be great.
unregistered
Guest
Oct 24, 2018
535
Although not scientific, I'd suspect the older style pictured above is correct for an S2 equipped heavyweight Streamliner whereas a later, S7 equipped middleweight bike would have the cloverleaf sprocket. Does your bike have S7s or S2s? Getting that SN buttoned down would help a lot, too.
Uni-Bike Lou
May 20, 2015
117
Hoffman Estates, IL
That helps, I do have S-2 rims. My frame and fork are for the S-2 rims, too. My SN is in both years which I understand is not uncommon. Thanks
Reactions: unregistered
unregistered
Guest
Oct 24, 2018
535
^Ah, I see your dilemma. Being a heavyweight bike, I'd lean on it being more on the '54 side then. Some folks smarter than me can chime in here on which year the Streamliner made the transition to being a middleweight, but I bet you need the older sprocket pictured above.
oldfart36
1,615
64
This Delta is a dellema!
The bottom, and all metal is nice and straight. But you can see the condition of top, visor and visor ring. Sure, I can put a repop top on, but then it's no longer real!
1151588
oldfart36
1,615
64
Lots of work trying to keep the ole boy as he was when he was taken apart over 25 years ago and boxed up. The attention to the individual parts is really paying off now (only things replaced are bearings). Beginning to see the light at the end of the tunnel!! Last thing will be a wipe down of the painted areas.
1155230
