Sexy Gormully & Jeffery Rambler Model 28 Museum Specimen! TOC Bicycle Porn, Step Right Up!
MikeVittoriano
On Training Wheels
Pump box details, the inner box is painted brass. I would love to figure out what tools are missing from the finely stitched tool organizer. When I opened this box today it was so exciting! You could hear something inside; to think I may have been the first person to open the box in 120+ years! It gave me thoughts about what Howard Carter must have felt when he first entered King Tut's tomb...
It's because of beautiful specimens like that why I enjoy bicycle so much
sbarner
On Training Wheels
If I counted correctly, the front is a 32-spoke wheel and the rear is a 36. I can think of a lot of reasons why the rim stampings might be different, either on purpose or just through inventory management. While shops often stocked undrilled rims, I would bet the manufacturers received them drilled, or had their own drilling setups and the stock of differently drilled rims would not always be 'in-synch'. Ditto for built-up wheels.
Rusty McNickel
Tool technology update: I've used this latest modification to retrieve my last Rambler tag. It's a threaded rod with a short hanger wire hook attached. There is much more control of the hook. None of the deflection seen in a hanger wire. And, if you need to move a leather plug, as I did with this one, there is more control in that too. Still a little risk pulling the tag out past the plug still in the tube, so be careful. I got lucky with this one.
First time seeing a stamped/written combination for the made date. All previous have been hand written, usually in red ink.
gkeep
Brant, were you ever able to pull the leather plug and access the tag? I was thinking a small plastic pipe on a low pressure vacuum hose for the plug.
